Tagged: 19.1, cfx, fluid-dynamics, Other, turbulence, turbulence-model
April 5, 2023 at 2:32 pm
FAQParticipantActually there are around 15 options. The arrow pull down under “Fluid Models” lists 5, but to the right of that is a second button with … on it. This expands to show the complete list.
- Skewness in ANSYS Meshing
