Why are the Gauss points shown on the element edge instead of interior for the contact detection purposes, using the Gauss detection method?
June 6, 2022 at 9:58 am
FAQ
ParticipantThe Gauss point based contact detection method uses the integration points from the contact elements, which are on the surface of the body.
- Does ECAD trace mapping support more than one type of trace material (usually copper) in the same layer?
- How can I understand Beam Probe results?
- ANSYS Mechanical: Fatigue Crack Growth Analysis using SMART Crack Growth
