June 5, 2023 at 7:06 am
FAQParticipantThe My Servers list on the Add New Servers page is populated only with servers that have current products associated with your name. If you have a server that has previously hosted ANSYS products but it no longer contains current products, you will need to add the server via the Add New Servers page. The Source Server and Destination Server lists on the Relocate Products page are also populated only with servers that have current products associated with your name. If you have a server that has previously hosted ANSYS products but no longer contains current products, you will need to add the server via the Add New Servers page.
