January 25, 2023 at 7:16 am
FAQParticipant1) If in a thermal simulation, the case geometry has many shell conduction zones, particularly if they are on the walls not connect to each other, there is a chance that the solution will show some heat energy imbalance even if all the residuals and monitors look converged 2) the reason for this observation is, the side walls for a shell conduction zone, if not connected to any adjacent shell layers from another walls, are by default treated as adiabatic 3) hence, if there are many such walls in your case, the heat imbalance at these side of shell layers amount to the overall heat imbalance 4) this can be particularly observed in cases having a lot of baffles modelled using multi-layer shell conduction model for ex., engine head fins, Vehicle Underhood Thermal analysis with multiple baffle frames modelled as shell layers, etc.
- Defining heat transfer coefficient (HTC)
- How to use Thin Walls with Thermal boundary conditions?
- ANSYS Fluent Student: Conjugate Heat Transfer in a Heat Sink
- In ANSYS Fluent, when the energy equation is enabled and viscous heating is enabled, must pressure work also be turned on?
- Thermal Analysis of a Radiator Using Ansys Fluent
- ANSYS Fluent: Overview of the Mapped Interface Technique for CHT Simulations (18.2)
- How to solve the warning: “Warning: zone of type interior found between different solids!”
- How do I get rid of convergence problems with energy equation in Fluent (especially since R15)?
- Simulating Battery Pack Cooling System Using Ansys Fluent
- Setting Operating Density for Natural Convection cases when density is modelled using Ideal gas law
