Why am I getting an error message from the AFSURF macro saying the areas are not meshed properly when creating surface elements?
March 17, 2023 at 9:00 am
FAQ
ParticipantCheck to see if you got any warning messages about the area element shapes. If so, turn shape checking off via SHPP,OFF.
- Does ECAD trace mapping support more than one type of trace material (usually copper) in the same layer?
- How can I understand Beam Probe results?
- ANSYS Mechanical: Fatigue Crack Growth Analysis using SMART Crack Growth
