While using prism layers along with poly mesh, the surface mesh gets splitted arbitrarily. How to avoid this?
Tagged: 19.2, FLUENT Meshing/Tgrid, fluent-meshing, fluid-dynamics, General
May 15, 2023 at 8:33 am
SolutionParticipantPlease refer to attachment to access the solution. Keywords: prism, poly, curvature, split, slice, chunks, density
1. 2056471.pdf
- Skewness in ANSYS Meshing
