While trying to import a Convective heat transfer coefficient in a Steady state thermal analysis “Coupled” to a Fluent simulation, gives an error message “Wall adjacent temperature data was not found at the selected surface”
Tagged: 19, General, mechanical, structural-and-thermal, structural-mechanics, transient
April 13, 2023 at 7:32 am
SolutionParticipantSolution: Please find the attached solution.
1. Thermal_coupling_Entuple.pdf
