While going from SpaceClaim mesh to Fluent solver I am getting following error. Error: File has wrong dimensions (3). Error Object: #f Error: Error reading “D:Design1.msh”. Error Object: #f Warning: An error or interrupt occurred while reading the journal file. Some commands may not have been completed.
Tagged: fluid-dynamics, Preprocessing: Geometry, spaceclaim
April 13, 2023 at 7:32 am
SolutionParticipantPlease refer to attachment to access the solution. Keywords: dimension, 2d, mesh
1. 2066920.pdf
- Skewness in ANSYS Meshing
