While doing design study why all other DPs go out of date when I am making changes only in CFD Post for only one DP?
April 5, 2023 at 2:32 pm
FAQParticipantIf you make any change in CFD-Post (even if it’s disabling the visability box of an object) all other DPs will go out of date. You need to update only CFD Post cell in WB. Or you can use stand alone CFD Post.
- Skewness in ANSYS Meshing
