June 6, 2022 at 8:33 am
FAQParticipantSMILES data can be included in thermo portion of a mechanism or in a standalone Thermo file. The instructions on formatting are in the Reaction Workbench manual. An example of a thermo file that contains SMILES data is below. ( The full file can be found in your ANSYS v18.2 installation at: …ANSYS Incv182reactiondataC2_NOx.inp)
THERMO ALL
300.000 1000.000 5000.000
! [_ SMILES=”[H]” _]
! [_ INCHI=”INCHI=1/H” _]
! [_ CAS=”12385-13-6″ _]
H -THERMH 1 G 300.00 5000.00 1000.00 1
2.50104422E+0 0.00000000E+0 0.00000000E+0 0.00000000E+0 0.00000000E+0 2
2.54747466E+4 -4.65341317E-1 2.50104422E+0 0.00000000E+0 0.00000000E+0 3
0.00000000E+0 0.00000000E+0 2.54747466E+4 -4.65341317E-1 4
! [_ SMILES=”[H][H]” _]
! [_ INCHI=”INCHI=1/H2/H1H” _]
! [_ CAS=”1333-74-0″ _]
H2 121286H 2 G 300.00 5000.00 1000.00 1
2.99142300E+0 7.00064400E-4 -5.63382900E-8-9.23157800E-12 1.58275200E-15 2
-8.35034000E+2 -1.35511000E+0 3.29812400E+0 8.24944200E-4 -8.14301500E-7 3
-9.47543400E-11 4.13487200E-13 -1.01252100E+3 -3.29409400E+0 4
- How do I model humidity in Fluent?
- Configuring and Solving the Chemical Species Transport in Fluent
- ANSYS Fluent: Describing Non-premixed Combustion using the Steady Flamelet Model
- ANSYS Internal Combustion Engine (ICE): Port Flow Part 1 – Getting Started
- Model setup: Setting up chemical reactions
- How do I use the Flamelet Generated Model?
- How can volume fraction be plotted in a species transport simulation?
- ANSYS Chemkin-Pro: Reducing a Combustion Mechanism
- I am running an electrochemistry simulation in Fluent. How can I access the electrochemistry reaction rates with UDF?
- Explanations on the warning Maximum / Minimum PDF table enthalpy exceeded in xxx cells (Non-Premixed or Partially-Premixed models)
