Tagged: 19.2, mechanical, static, structural-and-thermal, structural-mechanics
March 17, 2023 at 9:00 am
FAQParticipantPlease refer to the following link for Rate Independent Plasticity which talks about the mean or hydrostatic stress: https://ansyshelp.ansys.com/account/secured?returnurl=/Views/Secured/corp/v191/ans_thry/thy_mat1.html
