Where do I find the information on the total mass, the centre of gravity, and the inertia moments when point masses are included in the model?
August 25, 2023 at 12:16 pm
- Does ECAD trace mapping support more than one type of trace material (usually copper) in the same layer?
- How can I understand Beam Probe results?
