June 6, 2022 at 10:33 am
FAQParticipantLinks to sample projects are in the SpaceClaim API help file, available in the following location:
Program FilesANSYS Incv195scdmSpaceClaim.Api.VnnSpaceClaim_API.chm
where nn is the API version number (i.e., V19)
- Create Sections in Meshing
- How to reverse surface normal in SpaceClaim?
- Tip on exporting geometry in Parasolid, STEP format from DesignModeler
- How to Change the Direction of the Normal Vector of the Internal Face?
- ANSYS Fluent: Watertight Geometry Meshing Workflow
- ANSYS Workbench: Decomposition and Hex Meshing – Part I
- ANSYS ICEM CFD: Basic Blocking
- How can I create a 2D section from a 3D model in SpaceClaim ?
- What is the difference between patch dependent meshing and patch independent meshing?
- How do you turn a rectangular surface mesh into a triangular surface mesh?
