Tagged: 18.1, fluid-dynamics, General, no, workbench platform
June 5, 2023 at 7:05 am
FAQParticipantThere are 2 logs: Go to the session files in your project file folder Open the wbjn files in Notepad++ or any editor that can read such files. You can find what WB did as the last step before your session crashed. Another location to look at is %appdata%WorkbenchLogs
- Skewness in ANSYS Meshing
