Tagged: 18, FLUENT - SYS, Installation/Licensing/Systems, licensing, Other
June 5, 2023 at 7:05 am
FAQ
ParticipantClient log files will be in C:UsersUserNameAppDataLocalTemp.ansys Which is equivalent to %temp%/.ansys on Windows client machine where the product is run.
