Whenever I try to export the surface pressures from my transient acoustic analysis, I get the following error: “Error at host: Invalid element.”
Tagged: acoustics, compressible-flow, fluent, fluid-dynamics
January 25, 2023 at 7:16 am
FAQParticipantThe CGNS export for LMS and ANSYS Mechanical supports only triangles and quads. Any mesh element that is regarded as polygon (including cut-cell) would generate the error while exporting the surface pressure data. Keywords: CGNS, Error, Export, Acoustics
- Skewness in ANSYS Meshing
