When using the Trace import feature in Mechanical, is there a way to find out the metal fraction assigned by the program for each layer?
Tagged: metal fraction, Source Value, Trace import, validation
June 6, 2022 at 9:58 am
FAQ
ParticipantYou can insert a “Validation” into the Imported Trace object and then display the “Source Value” for each layer with the details shown below. The “Source Value” is the metal fraction. Use wireframe to avoid results being hidden by other layers.
- Does ECAD trace mapping support more than one type of trace material (usually copper) in the same layer?
- How can I understand Beam Probe results?
