Modeling & Meshing
Modeling & Meshing
When using ETABLE to read surface solution (e.g., ETABLE,xx,surf,9), nothing is saved. Warning: The requested database is not available.
    • FAQFAQ
      Participant
      If there is pressure applied in the model, the pressure setting needs to be set as Applied by “Direct” instead of “Surface Effect”. “Surface Effect” will create surface over solid to apply pressure. However Surface solution is available for solid element only.
