When using cutcell mesh in ANSYS Meshing R18, I keep getting the message “The shared license is not available for this application”. Why?
Tagged: 18, assembly-meshing, cutcell-meshing, fluid-dynamics, General, meshing
June 5, 2023 at 7:06 am
FAQParticipantThis warning did not appear prior to R18, when cutcell meshing was performed by calling tgrid. R18 calls fluent, which pulls the shared license if the Mesh editor is open. The Mesh editor goes Read-Only Configuration, but will re-acquire the license once the cut cell mesh is completed.
- Skewness in ANSYS Meshing
