When trying to run Ansys Mechanical on a Microsoft Cluster using MSMPI you get the following error. Resources file ‘C:Program FilesANSYS Incv190CommonFilesLanguageen-us/fx0.msb’ not found. CADOE_LIBDIR190 = C:Program FilesANSYS Incv190CommonFilesLanguageen-us.
Tagged: 19, hpc, HPC/Parallel, Installation/Licensing/Systems, Mechanical - SYS
April 5, 2023 at 2:32 pm
FAQParticipantAPPLIES TO ALL VERSION OF ANSYS RUNNING ON A MICROSOFT CLUSTER Resolution: Check your environment variables on the head node for this variable CADOE_LIBDIR190 If it reads: C:Program FilesANSYS Incv190CommonFilesLanguageen-us Change the path to UNC format \HEADNODE_NAMEANSYS INCv190CommonFilesLanguageen-us All ANSYS INC paths should be using UNC format on the headnode and all compute nodes (pointing back to the headnode)
