When trying to output a cfx mesh (hex mesh) from ICEM, why does a file chooser popup appear asking the user to select a .uns file which does not appear to exist.
March 17, 2023 at 8:58 am
FAQParticipantThe cfx mesh output filter requires an unstructured mesh format to be able to generate a CFX mesh. An unstructured mesh can easily be generated by ICEM from the structures pre-mesh. On the premesh menu, right mouse click to select ‘Convert to unstruct mesh’ which will create an unstructured mesh, which will be saved in a .uns file.
- Skewness in ANSYS Meshing
