When trying to open a WB project, I am getting the following error: Error loading container Engineering Data: DataSource does not exist. Is it possible to recover the project
Tagged: 19, fluid-dynamics, General, workbench, workbench platform
April 5, 2023 at 2:31 pm
FAQParticipantThis is likely only engineering data is missing. You can try to copy EngineeringData.xml from a new project into the SYS/ENGD which should fix the problem
- Skewness in ANSYS Meshing
