When trying to launch Icepak on a DCV visualization server you receive the following error: can’t load font screen14, using variable Handling signal 11
June 5, 2023 at 7:05 am
FAQParticipantResolution: (Applies to all versions of Icepak) You will need to add the following font’s to the /etc/vnc/config file Red Hat -fp “/usr/share/X11/fonts/100dpi,/usr/share/X11/fonts/75dpi,/usr/share/X11/fonts/Type1,/usr/share/X11/fonts/util,/usr/share/X11/fonts/misc” SUSE machines seem to not require this step
