When trying to enter APDL commands in Workbench Mechanical “Commands(APDL)” window on Windows 10, no commands are saved for either copy/paste or typing directly. Also, there are no syntax tooltips shown and right clicking the mouse for options says that the Commands APDL object is empty.
April 13, 2023 at 7:32 am
