When trying to add an evaluation or lease license file to the original one and trying to use the sum of the HPCs, I can’t access to the sum of the HPCs, why?
June 5, 2023 at 7:05 am
FAQParticipantThe dates of the HPCs increments of the added license file evaluation must be the same or an earlier date of the original license file and equal for the leased one because otherwise the “SUPERSEDE” code excludes the use of the added licenses.
