When submitting 2019 R3 Mechanical job to Windows HPC cluster through RSM using local scratch as working directory, everything works except 3 issues: •Job State in HPC Job Manager shows “Failed”, rather than “Finished” •Temporarily local scratch folder and solve.out file generated by the job could not be automatically deleted after RSM job is finished. •Below warning in RSM job report log: Traceback (most recent call last): File “head-nodeANSYS Incv195/RSM/Config/scripts/ClusterJobs.py”, line 1881, in exitCode = main(sys.argv[1:]) File “head-nodeANSYS Incv195/RSM/Config/scripts/ClusterJobs.py”, line 345, in main deleteLocalScratchDirectoryOnThisNode(nodeList, True, startingDirectory) File “head-nodeANSYS Incv195/RSM/Config/scripts/ClusterJobs.py”, line 727, in deleteLocalScratchDirectoryOnThisNode shutil.rmtree(_localScratchDirectory) File “head-nodeANSYS Incv195commonfilesCPython2_7_15winx64Releasepythonlibshutil.py”, line 266, in rmtree onerror(os.remove, fullname, sys.exc_info()) File “head-nodeANSYS Incv195commonfilesCPython2_7_15winx64Releasepythonlibshutil.py”, line 264, in rmtree os.remove(fullname) WindowsError: [Error 32] The process cannot access the file because it is being used by another process: ‘C:/local/kkyx4xml.xn5solve.out’
- exitCode = main(sys.argv[1:]) File “head-nodeANSYS Incv195/RSM/Config/scripts/ClusterJobs.py”, line 345, in main deleteLocalScratchDirectoryOnThisNode(nodeList, True, startingDirectory) File “head-nodeANSYS Incv195/RSM/Config/scripts/ClusterJobs.py”, line 727, in deleteLocalScratchDirectoryOnThisNode shutil.rmtree(_localScratchDirectory) File “head-nodeANSYS Incv195commonfilesCPython2_7_15winx64Releasepythonlibshutil.py”, line 266, in rmtree onerror(os.remove, fullname, sys.exc_info()) File “head-nodeANSYS Incv195commonfilesCPython2_7_15winx64Releasepythonlibshutil.py”, line 264, in rmtree os.remove(fullname) WindowsError: [Error 32] The process cannot access the file because it is being used by another process: ‘C:/local/kkyx4xml.xn5solve.out’" target="_blank" rel="nofollow" title="LinkedIn">
- exitCode = main(sys.argv[1:]) File “head-nodeANSYS Incv195/RSM/Config/scripts/ClusterJobs.py”, line 345, in main deleteLocalScratchDirectoryOnThisNode(nodeList, True, startingDirectory) File “head-nodeANSYS Incv195/RSM/Config/scripts/ClusterJobs.py”, line 727, in deleteLocalScratchDirectoryOnThisNode shutil.rmtree(_localScratchDirectory) File “head-nodeANSYS Incv195commonfilesCPython2_7_15winx64Releasepythonlibshutil.py”, line 266, in rmtree onerror(os.remove, fullname, sys.exc_info()) File “head-nodeANSYS Incv195commonfilesCPython2_7_15winx64Releasepythonlibshutil.py”, line 264, in rmtree os.remove(fullname) WindowsError: [Error 32] The process cannot access the file because it is being used by another process: ‘C:/local/kkyx4xml.xn5solve.out’" target="_blank" rel="nofollow" title="whatsapp">
- exitCode = main(sys.argv[1:]) File “head-nodeANSYS Incv195/RSM/Config/scripts/ClusterJobs.py”, line 345, in main deleteLocalScratchDirectoryOnThisNode(nodeList, True, startingDirectory) File “head-nodeANSYS Incv195/RSM/Config/scripts/ClusterJobs.py”, line 727, in deleteLocalScratchDirectoryOnThisNode shutil.rmtree(_localScratchDirectory) File “head-nodeANSYS Incv195commonfilesCPython2_7_15winx64Releasepythonlibshutil.py”, line 266, in rmtree onerror(os.remove, fullname, sys.exc_info()) File “head-nodeANSYS Incv195commonfilesCPython2_7_15winx64Releasepythonlibshutil.py”, line 264, in rmtree os.remove(fullname) WindowsError: [Error 32] The process cannot access the file because it is being used by another process: ‘C:/local/kkyx4xml.xn5solve.out’" target="_blank" rel="nofollow" title="reddit">
- exitCode = main(sys.argv[1:]) File “head-nodeANSYS Incv195/RSM/Config/scripts/ClusterJobs.py”, line 345, in main deleteLocalScratchDirectoryOnThisNode(nodeList, True, startingDirectory) File “head-nodeANSYS Incv195/RSM/Config/scripts/ClusterJobs.py”, line 727, in deleteLocalScratchDirectoryOnThisNode shutil.rmtree(_localScratchDirectory) File “head-nodeANSYS Incv195commonfilesCPython2_7_15winx64Releasepythonlibshutil.py”, line 266, in rmtree onerror(os.remove, fullname, sys.exc_info()) File “head-nodeANSYS Incv195commonfilesCPython2_7_15winx64Releasepythonlibshutil.py”, line 264, in rmtree os.remove(fullname) WindowsError: [Error 32] The process cannot access the file because it is being used by another process: ‘C:/local/kkyx4xml.xn5solve.out’" target="_blank" rel="nofollow" title="facebook">
March 17, 2023 at 1:11 pm
SolutionParticipantPlease refer to the attached PDF resolution document.
1. 2061195-revised.pdf
