Tagged: 19.1, fluent, fluid-dynamics, MP - Eulerian MP Flow, multiphase, phase-change
January 25, 2023 at 7:17 am
FAQ
ParticipantThe importance of Psat-Tsat curve on some of the cavitation simulation scenarios are mentioned below: 1. If cavitation is localized and collapses within a small region and the flow is nearly isothermal process, then the default method (where energy solver is off) with a single value for vaporization pressure is sufficient. 2. If cavitation is localized and collapses within a small region but the flow is non-isothermal, the local region at which cavitation may trigger will be governed by the local temperature, pressure and the corresponding vaporization pressure. Hence, in such cases specifying the Psat-Tsat curve can be important. 3. When simulating a flashing type of phenomenon where more amounts of vapor sustains itself downstream of the inception, then invoking the energy solver and specifying the vaporization pressure as a function of temperature can be important.
- Solver message during DPM calculation: “number of stepsize underflows during particle integration step is x”. What does it mean and how to get rid of it?
- What is the difference between the VOF model and the Eulerian model?
- ANSYS Fluent: Efficient Modeling of Spray Breakup using VOF-to-DPM Transition
- ANSYS Fluent – Eulerian & Mixture Multiphase Models & Applications – Tips and Tricks
- What is the superficial velocity in multiphase flows?
- Mixing Tank Modeling in ANSYS Fluent
- Hydrodynamics and Wave Impact Analysis
- ANSYS Fluent: Describing Cavitation in a Centrifugal Pump
- What do “incomplete” DPM particle tracks mean?
- How to obtain the input values for a Rosin-Rammler particle size distribution from measured data?
