March 17, 2023 at 9:00 am
FAQParticipantSince the CPU cost of using the warping DOF is very small, we actually recommend using it in all BEAM188 and BEAM189 models. The warping will only be detected if you 1) set KEYOPT(1)=1 to activate the warping and 2) restrain that DOF somewhere. If you just activate it, but never restrain it, the warping will not be shown. Some sections show more warping than others. For most cross sections, a torsional load will cause the cross section to twist. In many cases, this is not a big deal – i.e., the error will not be too large. However, for thin walled sections (I beams, channels, etc.), warping can be important. Incidentally, circular (round) shapes do not warp. Torsion causes warping, but many combinations of loading and beam section can cause torsion. For example, a transverse shear load applied at the mid-span of an open “C” section (fixed at each end) which is not applied at the shear centre will cause the beam to twist. We do warn the user that if a section of the beam structure were to go plastic, we do not recalculate the torsional shear distribution on cross sections in the deformed configuration. Instead, we recommend modelling such scenarios with solid elements.
- ANSYS Mechanical: Node Merge
- Is there a way to show the element coordinate systems so that I know what direction the bending moments are in?
- How to use ANSYS Workbench Meshing Virtual Topology
- I am getting an error that mixed order mesh elements are not supported. How to overcome this issue?
- ANSYS Mechanical: Node Move
- How can you identify the element types used by Mechanical?
- How to use ANSYS Workbench for Shell Meshing and Editing
- How can we apply different loading conditions on both the top and bottom of a shell/surface body, e.g., temperature on top face and convection on bottom face.
- What is the difference between shell 63 and shell 181?
- How to change begin node and element number for meshing in Workbench Mechanical?
