June 6, 2022 at 9:58 am
FAQParticipantUse Display option available under the “Result” tab to “All bodies” to show unscoped bodies as transparent in result plots. The default is to only display scoped bodies in a result object.
- Does ECAD trace mapping support more than one type of trace material (usually copper) in the same layer?
