When running ICEM, the tetra and/or prism icons are not present. This problem has been encountered on 64 bit machines running Linux.
March 17, 2023 at 8:58 am
FAQParticipantSet the following environment variables to the values shown: AI_ENV_VOLUME_MESH = 1 AI_ENV_PRISM = 1 It will be necessary to shut down and restart ICEM for the environment variable settings to take effect. If this does not solve the problem, it is advisible to check that the required licence keys are present and have not expired.
- Skewness in ANSYS Meshing
