When rerunning a legacy WB Project from an older release (2019R1 or older), sometimes the Solution Combination results produce wrong or inconsistent results. What is the cause of this?
March 17, 2023 at 9:00 amFAQParticipant
The Solution Combination GUI was redesigned in R2019-R1. To access the Legacy GUI, you need to activate beta switch. Confirm that each result set is included by checking the appropriate box next to the result in the Legacy GUI. If any result is left unchecked, that might be the source of the inconsistent or apparent incorrect combination result. Refer also to TFS Bug report 598139.
- Does ECAD trace mapping support more than one type of trace material (usually copper) in the same layer?
- How can I understand Beam Probe results?
- ANSYS Mechanical: Fatigue Crack Growth Analysis using SMART Crack Growth
- How to define frictional coefficient as a function of relative sliding velocity
