When Postprocessing steps were done in one of the Monitor views, how can I get back to the Monitor view?
Tagged: 19.1, fluent, fluent-post-processing, fluid-dynamics, General
April 5, 2023 at 2:32 pm
FAQParticipantProblem/Description: I defined some report plots. When I now go to postprocessing and e.g. generate a contour plot, it is displayed in the window where I was watching my monitor point. How do I get back to the display of the monitors? Solution: – If the monitor window was the one of the Residuals, click with the right mouse button on Residual in the Tree > Edit… > Plot (button next to OK) – If the window was a “Report Plots” or “Residual”, click on Calculate to calculate one further iteration or timestep. Then all Monitors are displayed again – If the reports were saved to a file, it can be imported as follows: Postprocessing > Plots > File > Load and then select the required .out file. To avoid doing Postprocessing on the monitor tabs, click with the right mouse button on Graphics in the Tree > Options > Active Window (increase the number until the “Open” button appears and use this one for Postprocessing.
- Skewness in ANSYS Meshing
