When opening a cas/dat pair in 2019R3 that have a saved solution animation that was saved in a location other than the default (working directory), Fluent prints errors when attempting to play the solution animation. The error is as follows: Error (TK_Error [1]) reading file: C:working_directory_filepathanimation_name_001.hsf Segment: ?active Why is this happening?
Tagged: 2019 R3, 2019r3, fluent, fluid-dynamics, General - FLUENT
March 17, 2023 at 8:59 am
FAQParticipantThis is a bug that is present in 2019R3 and was fixed in 2020R1. There is no known workaround for 2019R3.
- Skewness in ANSYS Meshing
