When one scdoc file is inserted into second scdoc file, NS are not retained. How to retain these NS?
April 13, 2023 at 7:32 am
SolutionParticipantPlease refer to attachment to access the solution. Keywords: named, selection, copy
1. 2068554.mp4
- Skewness in ANSYS Meshing
