When installing legacy Fluent license. It throws an error: can’t initialize: No SERVER lines in license file. This error is mostly on Linux servers.
January 25, 2023 at 7:28 am
FAQParticipantThe license file must be saved in ASCI format only. (On Notepad > Save as > select Encoding: ASCI) In any other format, license manager (FSLM 10.8) can not read the license file. Also, legacy fluent (license-fluent) can use host id of eth0 only.
