When installing a new license, the ‘FlexNet Licensing’ shows not running. Host id is matching and port 1055 is free. The license.log file is not created
January 25, 2023 at 7:28 am
FAQ
ParticipantRun command: “C:Program FilesANSYS IncShared FilesLicensingwinx64lmgrd.exe” -c “C:Program FilesANSYS IncShared FilesLicensinglicense_files” -l “+C:Program FilesANSYS IncShared FilesLicensinglicense.log”. Found the error, file format of ansyslmd.lic was not supported. The license file (ansyslmd.lic) must be in ASCI or UTF-8 format for Windows machine.
