When injecting a fuel droplet into the domain and calculating the mean mixture fraction through a plane, is it calculating the mixture fraction based on the droplets that pass through the plane or the evaporated species? Or both?
Tagged: 19, combustion, Flamelet Models, fluent, fluid-dynamics, Species/Reactions
January 25, 2023 at 7:17 am
FAQParticipantMixture Fraction can only be calculated based on gaseous species, so Mixture Fraction by definition excludes any fuel that is still tied up in the droplets. Ignoring the presence of the fuel droplets produces no error in the flamelet/flamespeed calculations. Liquid fuel never burns directly. It always has to go through the heating-evaporation process before any combustion can occur.
- How do I model humidity in Fluent?
- Configuring and Solving the Chemical Species Transport in Fluent
- ANSYS Internal Combustion Engine (ICE): Port Flow Part 1 – Getting Started
- Model setup: Setting up chemical reactions
- ANSYS Fluent: Describing Non-premixed Combustion using the Steady Flamelet Model
- I am running an electrochemistry simulation in Fluent. How can I access the electrochemistry reaction rates with UDF?
- How do I use the Flamelet Generated Model?
- ANSYS Chemkin-Pro: Reducing a Combustion Mechanism
- How can volume fraction be plotted in a species transport simulation?
- Explanations on the warning Maximum / Minimum PDF table enthalpy exceeded in xxx cells (Non-Premixed or Partially-Premixed models)
