When initializing a case, the CFX-Solver exits with return code 1 and the following messages: io_gunzip: Data error io_gunzip: decompressed too little data: got 43393 bytes, expected 960000 READ_BLKS_PAR : Decompression failed for WHAT=G/MFLOIP_FL1 WHERE=- ZN1/ES47 Stopped in routine READ_BLKS_PAR
Tagged: 18.2, cfx, fluid-dynamics, General, General - CFX
March 17, 2023 at 8:58 am
FAQParticipantThe most likely cause of this failure is that the results file is corrupt. If so, it won’t be possible to restart from this file unfortunately. Corrupt files are rare. The most likely reasons for a corrupt file are that the solver failed while it was writing the output file (for example if the system ran out of disk space or a power failure occurred), or if the file has been copied (for example via FTP) it may have been damaged in transfer. Try to recopy the file to see if the issue can be avoided.
- Skewness in ANSYS Meshing
