When I try to load my multispecies case into CFD Post, I encounter a failure and the error: ERROR Variable ‘Conservative Mass Fraction’ is defined as a scalar only
April 5, 2023 at 2:32 pm
FAQParticipantThis error usually coincides with species names that are longer than 32 characters, ie: ‘Argon gaseous at 1atm from 300K to 30000K’. is 41 characters long. Changing the name to ‘Argon gas at 1atm 300K to 30000K’ allows the solution to load into ANSYS CFD Post
- Skewness in ANSYS Meshing
