When I try to enter the backward rate of a Finite Rate reaction under Species Model in Fluent, I can check the checkbox, but then it becomes greyed out and I cannot enter the backward rate of my reactions. Is this a defect?
April 5, 2023 at 2:32 pm
FAQParticipantThis is not a defect. Once this checkbox is activated, Fluent will automatically calculate the backward rate of the reaction, so there is no need to enter it.
- How do I model humidity in Fluent?
- Configuring and Solving the Chemical Species Transport in Fluent
- ANSYS Fluent: Describing Non-premixed Combustion using the Steady Flamelet Model
- ANSYS Internal Combustion Engine (ICE): Port Flow Part 1 – Getting Started
- Model setup: Setting up chemical reactions
- How do I use the Flamelet Generated Model?
- How can volume fraction be plotted in a species transport simulation?
- ANSYS Chemkin-Pro: Reducing a Combustion Mechanism
- I am running an electrochemistry simulation in Fluent. How can I access the electrochemistry reaction rates with UDF?
- Explanations on the warning Maximum / Minimum PDF table enthalpy exceeded in xxx cells (Non-Premixed or Partially-Premixed models)
