When I set up a mixture material with the NIST Multicomponent Real Gas model, Fluent fails with the error: “Error: REFPROP_error (117) from function: setupn[SETUP error 117] TNo mixture data are available for one or more binary pairs in the specified mixture. The mixture is outside the range of the model and calculations will not be made.”
Tagged: 18, fluent, fluid-dynamics, Modeling/Setup Advice, Species/Reactions
June 5, 2023 at 7:06 am
FAQParticipantDespite its appearance, this failure is actually due to a known limitation. It is documented in the Fluent User Guide as follows: “For mixture flows, not all combinations of species mixtures are allowed. This could be due to lack of data for one or more binary pairs. In such situations an error message generated by NIST will be returned and displayed on the ANSYS Fluent console, and no real gas material is allowed to be created.”
- How do I model humidity in Fluent?
- Configuring and Solving the Chemical Species Transport in Fluent
- ANSYS Internal Combustion Engine (ICE): Port Flow Part 1 – Getting Started
- Model setup: Setting up chemical reactions
- ANSYS Fluent: Describing Non-premixed Combustion using the Steady Flamelet Model
- I am running an electrochemistry simulation in Fluent. How can I access the electrochemistry reaction rates with UDF?
- How do I use the Flamelet Generated Model?
- ANSYS Chemkin-Pro: Reducing a Combustion Mechanism
- How can volume fraction be plotted in a species transport simulation?
- Explanations on the warning Maximum / Minimum PDF table enthalpy exceeded in xxx cells (Non-Premixed or Partially-Premixed models)
