When I run ens_checker on data exported from Fluent, I get the following. Invalid part number (0) >————————-< > GEOMETRY section FAILED < >————————-<
- ————————-< > GEOMETRY section FAILED < >————————-<" target="_blank" rel="nofollow" title="LinkedIn">
- ————————-< > GEOMETRY section FAILED < >————————-<" target="_blank" rel="nofollow" title="whatsapp">
- ————————-< > GEOMETRY section FAILED < >————————-<" target="_blank" rel="nofollow" title="reddit">
- ————————-< > GEOMETRY section FAILED < >————————-<" target="_blank" rel="nofollow" title="facebook">
March 17, 2023 at 8:58 am
FAQParticipantThis won’t cause a problem for EnSight, but may cause a problem when reading the EnSight files in another program like Paraview. The workaround is to change the id of the surface in Fluent by giving the surface a new name with the Zone Surface Id feature.
- Skewness in ANSYS Meshing
