When I load a Mechanical .rst file in CFD-Post, the geometry is highly skewed and deformed. Why is this happening?
March 17, 2023 at 8:58 am
FAQParticipantThis is likely caused by a deformation scaling that is too large. Right-click in the viewer then select Deformation, then select a smaller deformation scaling.
- Skewness in ANSYS Meshing
