When I launch ANSYS Maxwell from inside Workbench 2019R1. Version 18.n of Maxwell opens and not the latest version.
March 17, 2023 at 9:01 am
FAQParticipantOpen Workbench 2019R1 Choose Tools/Options/Electromagnetics Set the path to C:Program FilesAnsysEMAnsysEM19.3Win64 OK File/Exit to exit from Workbench The next time Workbench is opened the link to Maxwell 2019R1 should now be correct.
