When I import an STL file into CFD-Post or EnSight for post-processing, the results don’t look correct. Why is this? What can be done?
April 13, 2023 at 7:32 am
Solution
ParticipantDefault STL meshes usually contain very large facets with high aspect ratios. As a result, when data is interpolated onto the STL mesh in CFD-Post or EnSight, the results don’t look correct. This can be avoided by refining the STL mesh in SpaceClaim. The attached recording shows how this is done.
1. 2058861 Refining STL mesh for improved post-processing.mp4
- Skewness in ANSYS Meshing
