When I edit the Parameter Studies table in Forte and click Insert Row, nothing happens. Is there a trick to adding parameteric runs?
Tagged: 19, fluid-dynamics, Forte, Forte General, Other
June 5, 2023 at 7:06 am
FAQParticipantTo have any entries in the Parameter Studies table, there must first be one or more boundary conditions set up as a parameter. Then when you click insert row, now rows will be inserted at the end of the table unless you click an entry in the the table. When you click an item, a new duplicate row is inserted before the chosen row.
- Skewness in ANSYS Meshing
