April 5, 2023 at 2:32 pm
FAQParticipantIn R18.0 and earlier if you make any modification to an object in CFD-Post all other DPs will be put out of date, needing re-solving. In R18.X, only the results cell of all other DPs will be put out of date. So you need to only update results cell.
- Skewness in ANSYS Meshing
