When duplicating project in WB and changing the geometry why the new geometry is not updated in Ansys meshing? How to update geometry in meshing.
June 5, 2023 at 7:06 am
FAQ
ParticipantWhen geometry is updated in DM and meshing component is already open, you need to update geometry in meshing using RMB (Right Mouse Button) on Model –> Update geometry from source.
- Skewness in ANSYS Meshing
