When doing a thermal analysis with phase change, what value of enthalpy is required? Does the thermal solver use the absolute enthalpy (H) or the relative enthalpy (H-Href)?
April 5, 2023 at 2:33 pm
FAQ
ParticipantMAPDL/Mechanical require total enthalpy. Enthalpy is temperature dependent. Material suppliers sometimes provide enthalpy vs temperature relative to some reference value (e.g., at 0oC). If relative enthalpy is provided, you must determine the reference value (Href) and add it to the relative value to obtain the total enthalpy.
- Does ECAD trace mapping support more than one type of trace material (usually copper) in the same layer?
- How can I understand Beam Probe results?
