Tagged: 18.2, fluent, fluent-post-processing, fluid-dynamics, post-processing
January 25, 2023 at 7:16 am
FAQParticipantIn a batch run a picture or animation shall be created, i.e. with the following command. > display savepic press_%f.png This might result in the following error: Error: hardcopy-window: No active window. Error Object: #f Output of graphics, i.e. pictures, does require an active window. This is not available when running a solver in batch mode. This situation can be handled by starting the solver with the following arguments as start options: -gu -driver null For example fluent 3ddp -gu -driver null -i journal_batch.jou >& outputfile &
- Skewness in ANSYS Meshing
